rswojo- Thanks, you are correct- that's a 5A fuse.. My little inspector has been by my side the whole time, and appears to be both confused and amazed that I plugged a lightbulb into one of my receivers..
Update: The recap is finished, the new output transistors are in, and I brought it up on the DBT.. Sound from both channels is good, but slightly distorted on the Left Channel (this is the one that had bad output transistors in it.. Also, the left output transistors are running noticeably hotter than the right.. So I have some issues that are still lingering, and I'm going to need some help/guidance from the gurus.. Here's the skinny:
1. Upon startup, the DBT Lights up and dims, but then starts glowing moderately again. It glows significantly brighter than the "control" 6060 that I put on the DBT next to it.. This bring up a question: Am I safe to start checking voltages while this is powered on with the DBT inline? That extra glow is telling me something must still be shorted in there- maybe on the left channel. I understand the DBT is eating up the amps, but I'm skiddish and I don't want to fry anything.. Note: I've been doing light restore jobs on amps for some time now, and somehow never used a DBT.. This thing is pretty neat!
2. After the full recap, DC offset drops to the single digits on both channels after being switched on for 30 seconds, but the left channel will have spikes up into the .060-.100 volt range.. I only replaced the output transistors, is this a sign that the other transistors on the board are malfunctioning?
Please let me know if there's anything I'm missing. So far it's come back to life, and I don't want to do anything that will cause the magic smoke to appear..
Thanks!!
MP
