Thatch_Ear
Addicted Member
MD,
You really should replace the 2 resisters that go from cathode to ground with a resister per power tube. Getting the power tubes properly biased will cut the heat down quite a bit. Order some nice 2 watt, low tolerance carbons from Electra-Print or Angela. It aught to improve the sound too.
I will be doing that to a 101-B after I get done screwing around with it.
