SwedishChef
Member
Bit of an update. I completely agree with your comment here. In fact I have read all the data sheets on the rectifier tubes and I believe the 5AR4 seems like the most stable rectifier choice. It also seems like less voltage drop will prolong the life of the rest of my tubes. I also agree about the 5V4 tube.@Lavane, have you experienced problems with JJ 5AR4 in a preamp application also? In a lowish voltage, low current application like this I would expect any old (or new manufacture) 5AR4 would do fine, including JJ. Especially if you do the “yellow-page mod with two series SS diodes”.
I believe a 5V4 will be a good alternative in this preamp, and certainly less expensive than NOS 5AR4. 5V4 is slow-warm and has just a bit more voltage drop that 5AR4; specs close to provided Chinese rectifier.
So I ended up finding an Amazon gift card that I completely forgot about, and I used it to snag an extremely high priced Genalex u77 / 5AR4 new production on Amazon. Should be leaps and bounds better than what it comes with.
