Bluetooth speaker build
Oops the why not wye is for mixing the input into a stereo amp not the output, sorry about that, I didn't mean to confuse.
Now that's a reasonable suggestion. It never would have occurred to me that there was an app for that.
If I did get one of those apps and sent a mono signal to the amp I could connect the speaker to either channel and it would play both channels through equally?
Also sorry to be a pain but I didn't really get your comment about the batteries and how much would be enough for 4 or 5 hours play time, can you explain? (maybe simpler) :)
Fun project here, congratulations! I can't speak for Android devices, but my little ipod touch has a mono switch buried deeply in the main settings. I use it frequently because I'm doing similar things over here, no Bluetooth though.
Biggles
I have a D battery pack (that can hold 3 D batteries).
Could I use them for this project?
No, you need at least 12V for this to work (actually I've found different specs saying from 8V to 14V minimum). 3 D cells will only give you 4.5 volts. Minimum of 10 rechargeables or 8 alkaline (if you think you're going to use both types, go for the 10 cell setup, the amp can operate on more than 12V, but 12V is a minimum). With good rechargeable AAs you should get at least 4-5 hours of playing time. Using more cells will give you a longer playing time, but don't exceed 24V.
I'm using 12 rechargeable batteries in two 6 cell battery holders in series. 1. 2v per cell gives me like 14.4v which will be sufficient correct?
