Carbsandcaps
Bear with me this may be a long one. Working in a bogen srb-20 with some strange biasing and voltages. It uses 6BM8 outputs. Pin 9 (the plate of the triode) has 90v instead of 120v. Pin 1 (the grid of the triode) has 20v on it.
The biasing has a weird setup. I’m supposed to have 20v on the cathode of the outputs but I can only get 15v. This circuit also feeds the preamp heater which I’m only getting 11v to. The circuit then goes back to the hum balance pots. I anlso found that the resistor to ground anfter the cathodes was 470ohm instead of 4700ohns so I replaced that. I’m assuming it gets the 20v from the voltage through the tubes? It sounds good and all the B+ voltages are good but I don’t like the low voltage on the triode plate and 20v on the grid.
