Bose 210 Series IV—good deal?
Joe-b
Hi there, I am a newbie starting to build my first turntable system, which I’m looking to build with a Technics tt. Quality sound is a priority; quality build and ease of use quickly follow. I am on a budget so I’m looking to start with quality, affordable components that I would upgrade as I am able.
I recently found a pair of Bose bookshelf speakers—Bose 210 Series IV Direct/Reflecting wired speakers. The seller is asking $30.
Is this a fair price? Are the speakers a good addition?
Thank you.
Welcome Joe B,
It’s no secret that Bose speakers in general don’t get much love here on AK .
I have no experience with the 210’s
I know the 901’s 501’s and 301’s can be pretty decent
All the Bose speakers do much better with subs
At 30$ not even a 1/2 a tank of gas
Make sure all the speakers work and the woofers don’t require new foam surrounds.
I would also suggest that you start off with the best possible speakers you can find and build a system around them. Maybe expand your search for something better than Bose
Good luck
Bobhorn
Joe,
you have to put yourself out there, Craigs list, Garage/Estate sales,
AK's own Bartertown, US Audiomart, Check for Ebay prices, if in a pinch.
Where are you located?
I would start off with Known brands, and ones that are somewhat efficient.(90 DB} or more.
Thanks Nyjblbob. I am near Syracuse NY. I’ll take a look at the places you suggest. The 90db or higher is really helpful, too.
One more thing to look out for, stay away from 4 Ohm speakers.
8 ohms seems ok with mostly anything
As discussed on other forums, some older receivers and most AV receivers
react badly get hot, blow protection devices ect.
You're in a decent area, even Canada has some screaming good deals.
Us and Canuk audiomart
There's a few of us on AK, in upper/mid NY with Way too much stuff,
:rolleyes: and willing to move something Good to make room for other Stuff
Joe B, if you come across Bose 601 series lll, those are really nice if you find them $200 or less. They don't require much power either. As for impedance ratings, as long as your amp is rated 4-ohm, you should be okay with most speakers in the 4-8 ohm range. Good luck and welcome to Ak!
