Blowed Fuse
ok ok ok….. It’s just a little pin prick
I picked up a set of 301’s on the cheap. The surrounds were gone so it turned into my first refoam. Many of you can probably tell from the extra glue I’m a novice. The room I put these in is small and filled with furniture limiting my options for placement to get the best sound from the rear facing tweeter. I thought to myself if the tweets were facing forward, placement would be so simple. The pictures are pretty self explanatory. Please keep in mind I’m not a carpenter or engineer. Didn’t even use a tape measure just eyeballed everything so the work is a little crude. I used ink pen tubes and long screws for the stands. The back screw is original just reangled it into an existing hole. I still need to line up one tweet thats a little crooked. Only one speaker done at this point so I’ve not got to test them out yet. Unless the crossover is doing something different to the rear facing tweet they should sound ok. The grill fits just fine.
