Bose 901 active EQs provide a range of nearly 20 db, from a low of -3 to approx +17 db. Most ordinary parametric EQs can't produce +17db. I have a set of 901s with a Bose EQ and a really nice Kenwood GE7030 14 band EQ. Ive tried setting up the Kenwood to reproduce the Bose EQ settings, the sound is ok, but its clearly not the same as when using the Bose EQ. Also note that with the typical limit of +/-12db of most EQs, you would need to shift the entire curve down 5 db to swing from -8 to +12 to get the full +20 db range of the Bose EQ. If you look at the attached graph, you will see the slope is incredibly steep at certain points. Its unlikely to find an eq with a slope that steep at the precise adjustment points that would match up with the band spacing of an ordinary EQ. Easiest solution to a bad or missing Bose EQ is to buy a mini DSP and program it with the curve depicted. Mini DSPs have a ton of flexibility to create curves far more precisely than adjusting the slider bands on an old school EQ. On eBay, there are multiple sellers for mini DSPs that are preprogrammed with the 901 curves. Or you could save a few bucks, and buy it unprogrammed and copy the curve for yourself.
