50nstillhifi
OK, let's get a few things straight here. First, Original Generation and Series II are the ONLY series that are power demanding. This was due to being Acoustic Suspension design. All other series are ported (bass reflex) and more efficient. According to the Official Bose website the Series III were introduced in 1976, which means development started well before this. That was also on the heals of the "power wars", when S.S. equipment began to exceed 100wpc. If Bose waited it out longer they wouldn't have had to go more efficient (IMHO). That aside, because the later model 901 were Bass Reflex the power demands were reduced. They can still "take" gobs of power, but are less demanding than their earlier brethren. I've powered my Original 901 with an 75wpc receiver and was quite pleased. However, the second point is the EQ is a must. I've spoken with people who haven't used an EQ and they were happy, until listening to a set with an EQ. The difference is quite huge. As for bass response, without the EQ they are pretty much gutless. With a parametric EQ you can improve things. Those are still pretty cheap and pretty common. But for the best bang you will need the correct EQ. Original and Series II can use either EQ interchangeably. Series III and IV, the same applies, as does Series V and VI, meaning the stated pairs will work with the same EQ Series. Example: you can use the Series VI EQ with a Series V 901, but not with the Series III or IV. I've had people shocked at the bass and highs from my 901 speakers, every time. Never fails. They've read the same BS, "Bose, no highs, no lows". Without EQ, sure, with EQ a whole different animal. Keep us posted. Those of us who OWN them are here to support.
I believe you to be "spot on" about Bose and their EQ matching. I have not had the privilege to own the 901s, but my brother did get the Series 3 after serving a tour in Germany. The speaker system was phenomenal! Of course, he had the complete system; EQ, amp and controller
.I am not sure why there is Bose-bashing when it comes to the design but you may have answered this if these speakers are used without proper EQ. The direct-reflecting technology is very curve dependent and to me can only be enhanced with the matching/comparable equalizer
.I have a set of Bose 301s, purchased back in..... I think the early 80s? I still enjoy this relatively low powered speaker set with all types of music. With proper EQ tapering the power fed (I use a 9100 Kenwood) .. they can be very loud, increasing proportionately up the scale. Unbelievably vivid, as well.
Anyways... I suppose I am wholly in support of your tribute
