special_20
Hello, I have recently acquired some Bose 901 series V speakers, stands and equalizer. Sadly I didn't get a chance to test before I bought. The equalizer seems not to be working - when I depress the "monitor" switch, It does not seem to engage the equalizer circuit.
I am trying to trouble shoot but have not been able to find a schematic. Anyone by chance have one or know of a source?
Anyone have experience trouble shooting these boards?
I am getting low/no sound out of both channels.
Diagnostic work to date:
- When plugged in I get power and see LED light up
- I have confirmed I'm using the "amplifier" inputs and ouptuts on EQ
- With eq connected to amp via amp's tape monitor circuit, and the amp's tape monitor button engaged, I get almost zero output form speakers (I have to really crank it to get any volume)
- With the amp tape monitor disengaged I get full volume
- The monitor button does not alter sound/volume
- This is on both channels
- I have tried 2 different receivers with the same results
- Disassembled and cleaned "monitor" and "bass" switches. They look and test good
- Inspected solder connections
- Applied fader lube to slide switches; checked with ohm meter and seeing good contacts.
- Replaced all electrolytic capacitors
- checked voltages on power supply and am seeing 35 vdc at test points on board and at filter caps
- Seeing voltage on all 3 legs of transistors in power supply
