bswinehart
I recently acquired a nice pair of A150's series 2's in VGC. Woofers were replaced with new OEM's from BA about four years ago and all drivers function well though I may check and/or replace the ferrofluid in the tweeters as these are 30 plus years old. Crossovers have never had any work done. I'm planning on recapping the crossovers while keeping the budget reasonable.
Based on a fair amount of researching forums on recap projects; I'm leaning towards replacing the caps and resistors as follows.
Caps:
Highs - Mundorf Supremes of equal value
Midrange - Mundorf Supremes or Dayton 1% polys
Lows - Dayton 5% polys or Dayton NP's
Resistors:
Mills non-inductive of matching values
I refoamed the woofers and recapped the x-overs (caps only, did not replace the resistors) on my original Boston A70's with great results using the Dayton 1% caps but I'd like to really make these A150's sound better than new.
I've read that the Mundorfs provide a noticeably more neutral and better overall response compared to the lesser priced Daytons (and comparably priced Solen, Audyn and Jantzen caps) in the highs and mids. I've talked myself out of spending much more for Clarity CMP's or other higher end caps since I'm not sure I'll be able to hear the difference above a certain level of "really good".
I'm looking for some feedback and/or thoughts on my selection(s) for this recap project. Thanks for your feedback.
Caps:
Resistors:
