Boston Acoustic A400 Surrounds Choice
wingzam
VIntage audio??
I just picked up these A400's and have been looking at surrounds. I'm reading that the proper surrounds choice is important and buying the wrong ones could cause some unspecified problem.
I see there is a series I, II and III A400. Mine are marked A400L with a serial number 08319. Does someone know which series these are?
Here are my choices for surrounds, which would be the best choice?
https://www.ebay.com/itm/Boston-Aco...hash=item28042647d4:m:mWalnXrGmTcnAzgAiP0WgGg
https://www.ebay.com/itm/Boston-Aco...746290?hash=item20d90216f2:g:uZAAAOxy4~BSTFeQ
And then there's a kit I read about from a guy named Cobb but I can't find a link.
Thanks for any input!
First one is correct I think, always fillited regardless of series, but email Rick Cobb at rcobb@tampabay.rr.com (I think) for cheaper and good advice because it avoids eBay fees. Good luck with the refoam and maybe a recap if you go down that road.
Thanks you guys, looking forward to getting these up and running! They're in excellent condition..and I only paid $80 for em!
Based on pictures, it looks to be next to the input terminal on back. If not, just see where the wires from it go.
I found the woofer crossover and it looks like the main crossover sits behind the Mid enclosure, but with a little thought (about all I have these days!) I just need to pull the tweeter and take a look...
I
Definitely replace the crossover capacitors while you refoam the woofers. Is it that big of a difference? YES.
I am waiting for my new capacitors. I will replace the woofer low frequency pass through filter caps when they get here from China. I could not find a USA seller but after ordering and paying for them I did find a UK seller that would get them here sooner IF I had purchased them from him.
