Pulled out my A70s to rotate into service for a bit and began mulling the technical aspects of these fine speakers. Not well versed in BA lore, I turned to the vast knowledge of the Web for enlightenment and am perplexed to discover no crossover schematic anywhere to be found. Seems odd for a very popular speaker enjoying ample buzz in the audio forums.
So it became a WTH moment, prompting me to pop one open and have a look. I have series I A70's, though with the Boston tweeter rather than earlier SEAS tweeter. The crossover in these is mounted on the terminal cup (unlike series II apparently). Mine look like this ...
... with an air-core coil mounted on the reverse side:
The coil is not labeled so I lifted some leads to measure it and the other components while already in there.
AND I traced out the schematic; to post here so I can find it next time I go looking.
It's surprising to find this woofer runs free. Unexpected enough that I double checked. No mistake -- red and black leads connect woofer directly to the input terminals. It is what it is, and seems to work well at that.
I Considered replacing those 37 year old caps but had no luck finding 6μF from the usual sources. Then I happened upon a couple from my parts bins. So I changed out the cap in the opened box. For now, its mate will retain the original cap for comparison. If it turns out the thing was better off before, I'll restore it as it was -- the original cap was left in place for that purpose.
