Rebuilding your Pas is a good option, and one poster has shown an option.
I had 2 very good condition Dynaco Pas preamps, and I rebuilt both of them with the Audio by Van Alstein Super Pas III kit. It replaces everything except the box and transformer. Replacement transformers are available if needed from various sources.
The kit uses the exact same tube compliment as the stock pas, but the circuit is anything but similar. Sound is very much improved and this unit stayed on stereophiles list of recommended components for years. They work reliably as hell, always work and sound very, very nice. The improved circuitry will drive lower input impedance amps, i.e. solid state without rolling off the frequency response. Plus, an extremely nice phono section is thrown in with the deal.
I can strongly recommend this unit and its phono stage, I've used them dailey since the mid 90's.
It also allows you to continue to use a component you may just be used to and would like to see stay in your system, albeit the insides will be different.
As to the Bottle head stuff, very well thought of and would no doubt out perform a stock Pas. To be very successful, and by successful I mean have it look decent as well as work, you need to be a bit of a craftsman. There are lots of examples of the units done by people who are. Personally, I dont like the look of a bunch of loosely cobbled together stuff that looks like a science fair project with a birds nest inside. Dont get me wrong, I've seen some very nice bottlehead jobs, and the sound is the big bang for the buck.
The looks depends on you.
As to missing the tone controls, whats to miss? As implemented, they are some of the worst I've seen, and a large improvement would be had by removing them in ANY case, along with the filters and loudness controls.
I dont know how plain the instructions are with these other kits out there, but the Van Alstein instructions are like the Dynaco instructions of old. Very clear concise, and if you can solder and ID components, its impossible to mess up. They will tell you how long to cut a wire, where it goes, etc down to the last detail. When done, it doesnt play radio stations, click or buzz while you are fiddling with it, it powers up extremely easy as well as down, due to the same tube rectifier the original Pass used. While I dont recommend doing this, it is one of the few preamps that if accidentally switched off in use doent make a big pop, nor does turning it back on with the power amp powered up, again I wouldnt recommend doing this either,
you will see your woofers slowly suck in a little, then slowly go back out. Dont ask how I know this.
Either path you take will allow you to learn a lot, that's for sure!:yes:
