Homer4beer
Well-Known Member
anything after it . example 2266 wrong way round etc etc
Not around the wrong way but brand new 220uF testing at 203uF ESR 0.06
That should be ok yes?
never tried one of them new ones . theory is same though .I thought the DBTs only were accurate with regular tungsten lamps and not halogen, no?
yes . now check the driver transistorNot around the wrong way but brand new 220uF testing at 203uF ESR 0.06
yep7266?
is amp at idle no speaker load ?
Check for dc voltage on spkr line (DBT power up), measure at 3356 and GND. Repeat for 3355 and GND. More than 700mV or so is bad.
YOU BLOODY RIPPA!
who freely gave of his time to make dozens of posts to advise on what steps to take, interpret my readings and, most incredible of all, EXPRESS POST, AT HIS EXPENSE, parts to repair it (refusing my offer of payment.)
You have excessive dc voltage on the spkr line. The protection circuit is doing its job and not connecting the spkrs.
Very unlikely you have a short.
Problem with right channel
These faults are a PITA to track down.
Two basic scenarios.
Component on positive half of amp has failed open so missing expected positive voltage to cancel the negative voltage (from neg half of amp)
Component on neg half of amp has failed short.
Understand that you've diode checked all components, however one is breaking down under voltage.
Will take some time to sort out a test procedure, maybe others will have a better idea.
Maybe take the night off...
The resistor 3298 had failed open so no +52V at all coming in.
Headphones are connected to the power amp, just like the spkrs.Uh oh. Might have celebrated too early .......no sound from speakers only headphones.
