Bozak 302A Tobin Mods
Artsy
Hello, I picked up a pair of Bozak 302A's in Moorish cabinets recently, and I need some help working on them.
I'm planning on doing the tobin mods to my Bozak crossovers, but I've got a couple questions, as this is my first time looking at a crossover.
Ideally I'd like to recap them the same way as the original, with multiple capacitors rather than a larger 25uf one, but I'm not sure if Dayton capacitors would fit in the original cap box.
Could someone describe the "jumper" to me? It's not obvious when I'm looking at it, but I would like to lower the crossover point to 400 instead of 800.
I've picked up some B200YC tweeters, but I've read that some people thought the tobin mod brings them down a little too much with the 7.5ohm resistor, how would I go about bringing it down about -6db instead? Can I use a different resistor around 4ohms? I'd prefer that over using an L-Pad.
My soldering skills are decent, and I'm pretty good about taking apart/fixing things and getting them back together again, but modifying something I don't fully understand is proving to be a challenge.
Also, does anyone know what kind of material the grill curtains are made of?
I'd appreciate any help, thanks!
Hello Artsy, sorry your post was missed, and welcome to AK.
There is a lot of help here for you. I'll get back with you as soon as I can but right now I'm headed out on a job. If you haven't searched here much yet, do do. Tons of info!
Try this thread, good info on everything and especially Tobin modded crossovers:
https://audiokarma.org/forums/index.php?threads/bozak-b-300-urbans-to-302s.871123/
Let me kn ow how it goes and we'll get you where you want to be!
Smiley
Hello Artsy, how is the research coming? Ready to make the magic happen?
Smiley
