www.lencoheaven.net/forum/index.php?topic=2932.45
(Quoting Bob Betts from the Yahoo Bozak group)
The foam used to damp the 209A does have a limited life. I have seen good ones come in for testing that were almost 20 years old - late 1970s, but have seen some that were only 10 or 12 years old that were dried up. Once again, the environment you live in can, and will, have an affect.
Actually, a clever experimenter could fix those rings by replacing the foam with a medium density polyurethane (open or closed cell) material, or even a soft latex foam. The density is really not too terribly critical as long as it isn't too soft or too hard.
It's purpose is to dampen the free-mode ringing that occurs when the cone comes to rest between excursions. It must compress against the cone edge suspension without actually displacing the cone (travel). Without it, the energy wave tends to travel up toward the suspension (that's normal) but then back down the cone due to the lack of damping (not normal). Peaks and phase distortion can result.
The "A" model did not last long before being replaced with the "B". Actually, the "B" came along, long before we knew that there was a life-expectancy problem with the "A".
