What you have looks like a 302A set-up. It doesn't look like any Bozak-made cabinet I've seen. You're right about the B199A (obviously), but the other driver you see is a mid not a tweeter. The date code stamped on the back refers to June 1961, so I'd bet those are paper coned B209 mids. There are most likely two tweeters mounted in front of the woofer. You can see the wires going to them and you should be able to see them with a flash light through the grill cloth. If they are the same vintage as the mids then they are most likely the paper coned B-200Xs. You can tell if they are with the flashlight because they have a silver-colored foil center cap. The later aluminum coned B-200Ys are all black. There might be a label on the mid in the other cabinet if you're curious to know which version it is. I think the number you listed must be a serial number. You can actually see on the crossover which drivers were meant to be used when it was produced. If it's all original then that's probably what you have.
