A week ago I went over to a friends house and heard his 0.75w SET amp on his Klipschorn's and was impressed. It was my first time hearing a SET amp.
I've repaired quite a few amps and have gotten quite good at it, but never built my own. I have a huge stash of tubes (including plenty of oddball novar, compactrons, etc) and parts. I'll probably start out with single ended triode, but might mess with pentode and maybe ultra linear as well? I have a few pairs of efficient speakers that it should work well with. I don't have any specific goals in mind (other than <3w or so), this is really just a learning exercise for me.
For now, power supply isn't a concern since I just want to get it going with my bench supply, a Fluke 407D, which can supply 555v @ 300mA (at <500uV noise) and has 10A of 6.3 or 12.6v. At some point I'll probably mess around with building a test equipment style regulated power supply with tubes, since I have a bunch of nice transformers and other things I scrapped from old HP and Tektronix gear. Totally unnecessary but should be fun to learn more about.
I was originally planning on using 6BX7GT's using this schematic that was shared by electra-print. It calls for a 2k primary OPT, which is part of the reason why I went with these specific Antek's since that's an option. The frequency response on them looks pretty good and they were cheap. I also haven't seen too many people use them, so it will be interesting to test the amp on my Rohde & Schwarz UPL when it's done for frequency response, etc.
This is the schematic for the parallel 6BX7GT amp that I found. Unfortunately I had one less 6BX7 in my stock, so will need to buy another if I go this route - or just use one tube for both channels for now.
I then found that I have a nice pair of 6EM7 tubes so I suppose I could build the amp from diyaudioprojects:
I found a bunch of 6L6G's (not GC), so could use them as well. I want to use some of my oddball tubes, not the standard 6550/kt88/el34/etc.
Anyways, I'll post more when I get there.
