Braun 1020s
yeah, those are not going to work. You need to find the original parameters and buy something as close as possible. these are going to be way off and 4 ohm. Give that Richard dude a chance to help you out.
K
I just repaired a set of these a few months ago. The original drivers are NLA but I have found excellent replacement woofers for them and tweeters also. I don't have the numbers here at work but I think I still have them at home. I believe th woofers I used are Pioneer from PE. I used speaker cabinet design software to come up with a good match.
A note about the onboard amps, they are not very good design. They use output capacitors and single supply quasi-complementary outputs. They do sound amazingly good. It would be possible to rework these speakers to use external amps. As they are, they are good at reasonable volumes but they don't give you much headroom for loud volumes.
Here's the woofer I used:
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=290-118&CFID=819608&CFTOKEN=93703598
And here's the response graph for the low end with that driver.
346933236%7Ffp343%3Enu%3D3279%3E83%3A%3E388%3EWSNRCG%3D3233689693%3B%3B3nu0mrj
Thanks Warren. They look like nice woogers. The speakers already have good replacement woofers so I wouldn't change them unless I can find suitable ADS or Braun woofers.
- Pete
- Pete
I think you might be missing the point here. Woofers in them are good for a car but the parameters and hence overall sound those speakers will reproduce will most likely be far from what the original designer was shooting for. The replacements suggested are, I'm assuming, a much closer match for the original woofers in the Brauns. The next best thing besides a perfect replacement if you will instead of something with much different parameters and therefore sound.
Yes, I plugged in the cabinet volume and the Theile-Small parameters of all the woofers that would fit the hole in the cabinet and this had the best performance. You do have to drill new mounting holes for them and there is a carboard gasket on the front of the woofer that just touches the inside of the grille on the speaker. I didn't have the nerve to try removing the gasket or cutting it, it didn't inerterfere with the operatiion of the speaker so I left it alone. You can knock out the original T nuts for the woofer and use them to mount the new one using the new holes. I plugged the old holes up with hot melt glue.
One more thing, I bet you can sell the woofers in it for about what it will cost you for those replacements. Win / win.
Thanks for the woofer sugestions. It had crossed my mind to sell the ones that are in there now to offset the cost of replacements.
Here are some shots of the guts. The amp looks very simple. Not much to it considering it is three separate amps. I was surprised to find a relay on the back of the lower plate. The coil leads go to pins on the din plugs. It looks like the relay is powered externally through the din plug. The diagram in the owners manual show’s a 30v feed. Strangely enough, they do power up without anything plugged into the din plugs so I’m not sure what that relay is for.
There is also a picture of the back of one of the woofers. It is a very simple and light weight stamped steel frame. Not very impressive. I still don’t have the correct din plug. I’m going to look for one tomorrow. If push comes to shove, I’ll just run wires off the back of the plug.
Warren,
Do you have any service information for the amps? Specifically bias and offset adjustments? There are several trimmer pots on the boards.
- Pete
That is way cool PETE! I would PM Soundmotor and get him over to this thread.
Also a lot of ADS speakers used 4 ohm woofers so you may be in the ballpark with
the woofer you have in there for now until you can locate a propper replacement.
(meaning an 8ohm woofer may throw the xover more out of wack then it already is)
Do they have an OHM rating on the back? Or no because they weren't designed for
external ampilification?
The woofers that are in there now and the original woofers are 4 ohm. The impedance of each of the drivers is called out in the brochure. The tweets are also 4 ohm but the mids are 8 ohm. I contated Richard So and he's looking through his stuff to see if he has something suitable. Said it would take him a few days.
- Pete
The woofers I used are 8 ohm, but it didn't seem to affect efficiency or sound level any. I played them at a pretty good volume and the amps didn't run out of gas, so I am ready to say that the 8 ohms work fine. I didn't make any notes on the adjustments and I have no service literature. The 3 large caps are the output caps. There are 2 pots for each amp, I think, one for center voltage, one for bias. The tweeter amp may have only had one pot, I can't remember. The center voltage is measured at the lead of the output cap closest to the heatsink, and is adjusted for 1/2 the voltage on the supply for that amp. Each amp has 2 output transistors and one of them has the supply on the collector. The other collector will be about 1/2 supply, same as the output cap. I think the T03 transistors were for the Bass and midrange amps, and inside there are T0220 transistors mounted to the heatsink for the tweeter amp. Adjust the bias for 20mA through the emitter resistors.
I recommend replacing the output caps, they will have dried up some by now.
Oh, and the crossover is active, so the speaker impedance doesn't affect it.
Hey Doc just so yu didn't didn't think I was knockin yu, I was just refering to the point
the woofs in there being 4ohm may not be a bad match if they were originally 4ohm.
I'm sure yu didn't but wanted to clarify anyway. :D
I tracked down 7 pin din plugs today and made up a pair of din to RCA interconnects. Hooked them up to a Sansui G-22000 receiver/preamp and plugged them in.
They sound great. Very full and detailed. All the drivers in both cabinets work and sound good.
Warran, thanks for the information. I'm going to recap the amps and do the adjustments you mentioned. Did you notice if there have a crossover network somewhere?
- Pete
I have L880s L780s and JBL L166s. I use the L880s mostly. I need to position the 1020s to give them a fair compairison to the L880s. My first impression is the 1020s are a much fuller sound. Time for a shoot out.
- Pete
I am very fond of the L880, no I'm not stupid and don't think there the greatest
speaker, but they do everything and all kinds of music very well for me.
I'll be interested in your thought's and again congrats on a very cool find!
LBPete Did you notice if there have a crossover network somewhere? - Pete[/QUOTE said:
Pete, the crossover is active, before the amps.
Kegger, no offense taken. I couldn't find any info on the 1020 when I was working on them and assumed the woofers were 8 ohm. I should have measured them. As it turned out, the 8 ohm woofers I used work fine in there. The sound level matches the other drivers.
Using a 8 ohm woofer in a 4 ohm designed XO drastically changes the XO point for the woofer. Not saying it still can't sound acceptable but it will sound nothing like originally design to.
You can play with it here... http://ccs.exl.info/calc_cr.html
