One cannot rely on any test record to set up a cartridge, as far as alignment goes.
Yes, a record, almost any will help you hear problems, but if you hear any, then suspect something not set up properly, such as overhang, proper null points, anti-skate, azimuth, VTA, and VTF.
The records can help, they are a valuable tool. If you cannot determine where your mistakes are, then the records become useless, if you don't know what to look for, or can determine what the errors are (Sibilance, mistracking, poor sound, lack of highs, or lows, etc).
LPs like the Cardas Sweep+Burn, Hi Fi News, Shure, etc, will help with many confirmational checks, knowing you have your Cartridge wired properly, that you're in phase, and can run-check many other tests.
But these aren't the only reliable, good tools one should have.
Read, read, read, and study. The more you learn, and know, the better to your advantage. Mark
