Dearslayer
So I finally did. After I replaced all the indicator bulbs on my 2325 I went to replace the dial string protector bar and in so doing I dropped a small screw down in the receiver. In trying to retrieve the screw I turned the receiver over and laid it on the bench hoping the screw would fall out. When I did I thought I heard a small crunch. The small screw fell out and I carried on. That's when I noticed the broken dial pointer. Has anyone had any luck when gluing the pointer in place? My thought was that it may not emit the light all the way through if it's glued.
