Broken Mitsubishi DA-A15DC
cjs27410
My Mitsubishi amp DA –A15DC- stopped working last week. I purchased it in ’78 and this is the first trouble I’ve had.
After about an hour or so at 30-35% volume the left channel made a scratchy noise and both speakers stopped working. The entire left side does not warm up now. I removed the lower screen but I don’t see any fuses.
Is this amp worth fixing and can anyone recommend a repair shop? I’m in Greensboro but I can UPS it anywhere.
Thanks for the help.
Could be any number of components that failed. Any smoke or odor of overheated components?
Ron
I can fix it in Nashville. Typically there is a zener in the diff amp stage that opens, so the diff amp no longer works. I replace both channels even when one is bad. My address and stuff are in my profile. When you ship, put the amp in a double box so the heat sinks are supported. They are not as strong at the bottom as they look.
PM sent
