I acquired this Bryston setup last weekend.
Date code on the 3B is Nov. '94. Board in BP20 marked 1993. Cleaned out dust, cleaned and lubed switches, contacts. Waxed cabinets.
I've posted about it in the Jazz thread to others nausea, I'm sure.
It shifted out a Rogue Cronus Magnum V1 tube integrated, 100wpc@8ohms. I was quite satisfied with the the Cronus, driving Magnapan 1.7i speakers.
But the added horsepower, (125wpc@8ohms), 250wpc@4ohms of this SS amp gives more and tighter bass. Through the 1.7i, which are 4 ohm and 86db spl. Now, this is my impression.
It is brighter than the Rogue. I have a Schiit Loki 4 band EQ in it's tape loop. I can reduce treble slightly for CDs or use its bypass switch for vinyl.
BP20 dosen't have a phono stage. I'm using an EAR834 clone 12AX7 phono preamp.
