Night Wolf
White Woofer Night Wolf
anyone have any info on the BSR 810?
I was intrigued by the wood plinth & lesser amount of plastic than the typical BSR <g>, so I did some more checking. It appears that this TT was reviewed in the May, 1972 issue of "High Fidelity" magazine. As I had guessed, it seems it's one of BSR's older and better models (the audio rags don't bother with complete junk). Try doing a Google search on "BSR 810 turntable" and see what you come up with... apparently manuals are available. If you get it set up properly, it probably won't damage records (provided the tonearm bearings are good) and may even sound halfway decent.Originally posted by Night Wolf
The complexity of the mechanics looks a bit overblown too... I'd be iffy about a unit that hadn't been refurbished (there's too damn much there to break, wear out or go out of adjustment)... but the general lack of plastic and heavy platter is intriguing. Now I've got an itch to hear one (but probably never will)...Originally posted by vinylengine
I just saw some great pics of one on eBay:
BSR 810 auction
It does look like the build quality was greater than most BSR's - not sure about the tonearm design, I guess the square profile makes it easier to balance pennys on to adjust the VTF![]()
Its that kind of talk that pushes the prices up - we'll have to keep this one to ourselvesNow I've got an itch to hear one (but probably never will)...
