Bsr c123r.a.2
MrOldtuberad
Hi friends!
I have a BSR C123R.A.2 with a problem in the lift arm system, I think that someone inside is broken or disconnected, I have already solved the common problem of dry grease etc, but remain this problem and if possible I don't want remove all parts from chassis for try to fix it.
Thanks a lot!
Bye
Some details and pictures might help. Right now all we know is it doesn't work. You can download service manuals for a lot of BSRs at Vinyl Engine, and if its the usual mechanism, it doesn't matter if its not exactly the same model.
It turns out that the VinylEngine has some BSR owner's manuals, including one for the C123R, but no service manuals which is what the OP would need to refer to. I'm afraid that digging around inside for broken, jammed or out of position parts is the next step.
John
Actually under idler table there is the C159 and one other that have service manuals. Probably will work.
