haromaster87
Hey guys,
So I bought this BSR passive subwoofer today for my living room system. It's a sealed enclosure with a 15in driver. 20 Watts minimum, 150 watts max, and has a built in 120hz crossover. 4ohm resistance, but the guy had the resistor pack that came with it to make it 8ohm. From what the guy said it was from about '89 or so.
It was made when subwoofer outs weren't very common yet, so it has speaker inputs from the amp and then speaker outputs, to go to the main speakers and use the internal crossover.
My pre-amp has a sub out though which I was going to run to a power amp and run to the sub. I believe the preamp crossover is 80hz which is better than 120hz. This all seems simple enough except for one thing.
On the subwoofer, next to the speaker terminals, there is a warning label that says not to plug it in and use it unless you had the main speakers hooked up to it, as running just the inputs to the sub with no speakers on the outputs will apparently damage the sub.
Can anyone think of why? Perhaps a design in the crossover that needs the load of the speakers? This sub is probably the most well taken care of piece of equipment I've bought, so I don't wanna hook it up in a way that will damage it, but I don't want to run any of my main speakers through it.
What would likely be my best solution here? I'm guessing maybe remove and set aside the crossover and just make a new plate to screw in place of that with just a set of speaker terminals going to just the driver with no crossover since the preamp has the crossover. Any other ideas before I get to work on that?
Thanks guys!
-Tony
Thanks guys!
-Tony
