The main thing is the current. If the amp draws 1.2A then the secondary of the bucking transformer needs to have that current rating, bare minimum, at the voltage you want to buck/drop.
If the transformer you are looking at is only rated in VA and voltage then you need to divide the VA by the voltage to get the rated current. Eg, 24VA @ 6V = ~ 4A.
