UsableT
Member
I've got an old Kenwood that still works well. I also just bought a new AudioEngine N22 (solid state A/B) and am curious whether my aging ears will be able to hear much of a difference if I use the same input (a DAC connected to my computer, for the music) and same speakers. Thus I will build an A/B box not for swapping speakers, but swapping amplifiers. I'll also need a box to swap the DAC in between the amplifiers; and of course a way of measuring output level for each amp to make sure I set them both about equal.
I haven't thought much yet about the A/B box for swapping the DAC from one amplifier to another, because I'm still working out the details for swapping the speakers from one amplifier to another.
I did some doodling on my own & then went online to look at what other folks have done. Two possible routes seem to be 1) just use a mechanical DPTD switch, or 2) use relays that perform the DPTD duty, and add a mechanical switch on a long lead that goes to the relay; thus allowing you to sit back in your chair to do the switching.
The purely mechanical route would be something like this person did: http://audio-room.net/connecting-2-...eakers-making-an-ampspeakers-selector-switch/
The option to add relays would be more like this article on Rod Elliott's site: https://sound-au.com/absw.htm
And here is someone else's recipe for a relay-equipped switch: https://www.audiosciencereview.com/forum/index.php?threads/ab-x-testing-of-power-amplifiers.20464/ Note that the schematic is only for one channel, so you would need to double it to serve the other channel, I believe. With a relay with enough contacts/throws this could be done - he uses a type of relay that I frustratingly cannot sufficiently identify to make possible a search for something similar on DigiKey or Mouser).
I like the idea of the relay version & being able to back in my chair and push a button from there without having to get up & go over to the amplifiers to fuss with the switch. (I'd have to come up with a long-lead pushbutton for the DAC switch, too, obviously.)
My big hangup here: I've never worked with relays before; so first step is I'd need to learn how to buy one with suitable values. It's not much help for me to go to DigiKey or Mouser until I know the parameters that will suit.
So I guess my question is, has anyone worked with relays enough to recommend particular values (e.g. switching voltage, max amps & volts, etc.) for appropriate SPDT or DPDT relays? That would make life simple enough for me that I could go shopping & work up something I could build pretty quickly.
Thanks in advance -
Thanks in advance -
