Thank you. I had seen this site but did not see the part about ordering the prints from him.
Man that would be wonderful if you could do that. I’d be very grateful.I have a couple plinths that I built for a sp10 Mk II. I can trace the opening or even make a cardboard template if that would help. I don't think I'd pay for a template.
Have you ever worked with panzerholz before? Damn toughest wood I have ever worked with.
I figured as much on the panzerholz but it can be routed can’t it?
I read someplace that you have to use diamond router bits to cut this stuff?
Why not do as I did, measure the bit that needs to go through the hole, measure the lip that sits on the plinth and measure relation of screw holes. Really not hard to work out hole size.Ok. So many questions. I think I’m going for a solid look. I’ve read the information published on the sound transmission characteristics of panzerholz, which is a compressed birch plywood of some sort originally from Germany. Very dense and apparently no transmission of sound characteristics. Just a dead thump.
I’d like to make it 6 -8 inches high and I really only need one arm board.
I think I’d like to have a dark high gloss coating as the color.
I really fell in love with the Porter plinth referenced above by Infantry Man. Maybe darker with a burl wood maybe.
