Interesting-
Around 19 years ago, I purchased a Mac C22 preamp, and thought how nice it would be to be able to turn it on and by doing so it would energize 4(1 for each +/- speaker wire)30 amp 120 volt relays using one of the C22`s 120 volt switched outlets.
I desired to do this so to be able to switch out the normally connected to the sunrooms DQ-10`s Mac C27/MC 2205/2 Velodyne ULD 15 powered subwoofers setup, to switch over to what ever tube amp/s I might be rotating that would be driven by the C22 for a total tube stereo listening experience, when the mood struck me..
I used the octal type relays, and barrier strip/w screws style sockets for any future serviceability and the reason of the seemingly over kill of the relay`s contact current rating, was 2 fold: #1 for extreme reliability, and #2, was when a very high wattage SS amp would be hooked up to that system, that there would be little chance of stressing the contacts when cranked up(also the same consideration for the all day normally in use MC 2205, and when switched over to my tube amps.
Has worked flawlessly for these nearly 20 years, with no connected tubes ever energized without a speaker load, as the volume of the C22 is turned all the way down before switching in or out.
And of course, in this setup, I had to build a separate line level high isolation 12v. multi coaxial reed switches in it`s own metal box system to deal with the L/R signal`s in`s/out`s of the Velodyne`s power amps crossover to facilitate the switch between the two systems using a 12v non switching wall wart also plugged in to another of the C22`s back panel switched power outlets.
I just turn on the C22, and all switch over connections are automatically made, and after 20 seconds, or so I advance the preamp`s volume control to whatever level I wish.
So, IMO/E it can be done reliably, and safely unless the industrial grade speaker connection relay`s 120v coils fail,..
As a connected tube amp`s output transformer safety check, I always first mildly turn up the C22, and if I didn`t hear any sound out of the DQ 10`s, I would shut off the C22, and investigate the reason, though no problem/s/failures so far.
Just a thought folks.
