Poultrygeist
Lunatic Member
Brett, with your ability you should be building speakers rather than stands. Great job!
Don't pour concrete mix inside, it retains moisture, and in a few years, if you want to repaint them, pouring the concrete out will be a pain in the neck, and there will be dust flying everywhere.
I'm thinking I could line them with heavy plastic such as contractor bags, by cutting a couple holes in the bottom of the bag, feeding it down over the rods and then putting on the lower fender washers and nuts (see pic); that way the holes in the bags would be somewhat sealed by the washers.
I could do this even before sliding the post down over the rods/bag.
Double up the top plates? The upper plate would bolt to the speakers and the lower one would bolt to the rods. Screw the lower plate to the upper one with screws coming up from the underside of the lower one.
Just a thought.
Oops! I like the pink
Install allenhead cap screws in the holes and use a ball end allen wrench to secure them to the speakers.
Right now, they are at the stage of useability, although I still have to paint them, drill mounting holes to bolt the speakers on them (the cabinets have tapped holes to screw them to a stand), and fill them with sand or lead or cat litter (or a combination thereof).
Beautiful, that's what I'm going to do then.(...)Since you already have holes in the current top plate you wouldn't have to counterbore the new one as bolt heads would be recessed in the the bottom top plate.
Focal has resale value, DIY really doesn't. That would be a huge reason for me to buy outright. I built a pair just because I wanted to.
