My Pioneer was recently the victim of the voltage-stabilizing transistors in the power supply de-soldering themselves over time, due to stress from thermal cycling. I've fixed every cracked solder joint I could find, and now the receiver is in tip-top shape again.
I really don't want this problem happening again. The voltage transistors in this unit are the hottest part of the whole receiver, everything else runs relatively warm. And when I say hot, I mean HOT. I can't even touch the heatsinks of the transistors for more than 2 seconds, or it'll burn me.
I've been considering buying a cooling pad to place on top of the receiver, so it can blow cool air down onto the components and out through the side vents. Does anyone here have a setup like this? What are some recommendations for fans?
