Hi All,
I have a high-power Adcom GFA-7805 five-channel amp that has a weird problem. I'm wondering if anyone has encountered similar or has insight into it.
When the amp is connected to speakers without interconnects, the amp is quiet -- just some very slight hiss, which is normal.
When the amp is connected to speakers and with RCA input, the amp has a very small amount of low-level hum through the speakers. This seems normal and doesn't affect listening.
When the amp is connected to speakers and with XLR input, the amp has audible/intrusive buzz through both speakers that's identical for any/all channels. If I unplug the interconnects at the source or the amp, the buzz stops. If the source is disconnected from other components, is turned off or unplugged, the buzz continues. I've tried multiple preamps and XLR cables, and this issue persists.
I should mention that the amp works perfectly and has done so in the past. There are no thermal or distortion faults (the amp has LEDs on the front panel for both). It plays music even with the buzz, doesn't overheat, and doesn't buzz mechanically except for a few second after it's switched on.
I've tried lifting the ground of various components, including the amp and preamps, and the buzz persists.
Finally, I should mention that my audio system is two-channel only and has no PC or network components. Just a couple of disc players, phono stage, turntable, preamp, etc.
Does anyone have any ideas? Thanks.
