JSMATT
Member
Having re-assembled the 2102, was setting bias for the two sections (equal. and Flat Amp)
Then, smoke began appearing at resistor R2 a 4.7Ohm .5W resistor on the Power Supply board (maybe 5 min or so in).
Almost all the Power Supply boards pieces were replaced with the exception of the transistors. This includes the three on the aluminum heat sinks (one SD357 and two SC1845s). So, all caps, resistors, and diodes. Sansui glue was a reason to take this path.
The original resistor was not fried prior to my receipt of the unit, but clearly something is now wrong. Now, it is becoming brown from overheating.
The three heat-sinked transistors have been reseated with fresh conductive paste.
R2 supports the middle sc1845 transistor.
Thoughts on likely problem sources for why it is overheating would be much appreciated.
