Above is from an old post. His description accurately describes my problem. Looks like the OP did not get much action - LOLI don't know how else to describe it. It's only one channel of the phono section. It sounds like a microphone in the wind. Is this what a bad transistor sounds like? Or is it like everything else in my life, "it needs to be recapped"
There is a schematic here http://www.hifiengine.com/library/mcintosh/c26.shtml
I have the same problem. It was working fine last week. I tried to play an album last night and the left channel was shot. I only had time to test a few things. I switched the left and right RCA inputs from the turntable and the problem remained the same. I moved the selector switch to 'phono 2' and the same sound was coming from the left channel (phono 2 has grounding plugs in the RCA jacks). I changed the mode switch to reverse and the problem moved to the right speaker.
This quick testing makes me think I have a problem in the phono section on the left board as all other functions of the pre are working great (tuner, aux). Before I take the unit out of service I was wondering if anyone else has had this problem or knows what usual suspects I should look for. Also, am I doing any further damage by continuing to use the pre in aux and tuner?
The unit has never been recapped that I know of and probably needs a full refurb but as always, I would like to find and fix the problem before I start a refurb project.
I was hoping that there was a separate board for the phono section but it seems that the phono sections are on the left and right boards.
Thanks for any ideas.
Attached is the service manual.
