c-33 query
Hi,
I just bought a C-33 off of a young lady locally (via Craigslist). This is my second Mcintosh acquisition (the first being a pair of MC75 monoblocks). What is common to both is the minimality of information online about them (i.e. users panning them or gloating about them). I have not yet connected the C-33 to my system and while I am very happy with my MC75s, I am wondering if anybody on this forum can shed some light on whether C-33 is being used by folks out there or not, and how is their experience? I am assuming that sometime down the road both systems will be visiting Terry Dewick, but any other advice/suggestions for getting the best out of the C-33? I was planning to use it in a 2-channel mode to drive my Magnepan MMGs via a NAD amp (the 75s are driving the top frequencies of my Revel set in a 5-channel system).
C33 is a great preamp with lots of flexibility and unique features. Do you have the owner's manual? C33 was the C1000 of its' day.
Thanks,
Ron-C
Re: manual
Hi,
Yes, I do have the manual and she also gave me the schematics for the system. It was her dad's sytem apparently, and he passed away in 1995 and it had been sitting idle all this time. (I think it was last serviced in the early 90s, but I could be wrong since she was very sketchy about it).
It powered up last night very nicely and drove my Maggies great. I think the dials/knobs had been stuck in their positions for quite a few years, so when I turn the balance/level and a few other knobs, I hear crackle. Should I open it up and spray some deox inside, or wait to ship to Terry in a few months? Also, I notice that you can see the inside lit up (when you look in thru the screen on the top). Is that normal? I assume it is.
Also, is it a 2-channel preamp only, or can I try to run my LFE to the sub separately (i.e. 2.1); the MMGs are weak on the bass:sigh:
You could run the Rel sub with your Maggies in a 2.1 setup as this is the way the Rel is designed to be used. Just working all of the controls on C33 a few times will help clean them up. Some Caig de-oxit and Fader Lube will usually make the controls work like new.
Thanks,
Ron-C
I am not too familiar with using De-oxit. Do I spray it on the outside or should I unscrew the top of the preamp and spray it indiscriminately inside or aimed at some locations? I assume the lube is only on the knob rods (outside)
Thanks,
Ron-C
BB,
Both products are to be used on the inside of the switches only. If you have not cleaned switches before you may want to have a tech do this or practice on an old receiver before you try on the C33.
Thanks,
Ron-C
The C-33 is an outstanding piece of gear. I have had mine for many years now, and have never once considered replacing it.
I particularly enjoy the 5-band EQ & expander. Here's a bit of functionality that I've made use of: The record source selection is independent of the listen function. While I still maintain a rear panel connection to my cassette recorder input, I also use this to route sources to another system in my home. (ie: turntable, computer/MP3 files, tape playback). As you will realize over time, this is a very flexible, feature laden preamp that does everything well. Enjoy.
There are a couple of good threads on the use of Deoxit over in the Vintage Solid-State forum. Very thorough.
Google Roger Russell's McIntosh History and check out the preamp section (scroll down). You can also check out Berner's McIntosh for the C33. Both have good info and pic's. Sometimes Berner's won't give out the info. Also, check the database sticky at the top of the page in this forum. May be some C33 info there.
