All worked yesterday - the last time I ran the C-4. I had a power button light burnt out - it's happened before and I planned to swap bulbs for LEDs. I pulled the case and front panel, and removed the bad bulb at the power switch. Plugged the unit back in to figure out which LED lead goes to the red & white wires, and I now have no power at any of the bulbs. I used to hear a relay click 3-5 seconds after I push the power switch - now I hear nothing. I cycled the power switch a number of times and checked for power at the switched outlets - all good. Checked the four fuses by the power transformer - all good. Checked primary side of transformer - good. What should I be looking for next?
