C-80 phono selector switch issue
Clean yes. Correct tension on the contacts no. You don't have to tweak them much to render them unserviceable.
I know first hand with a Technics preamp switch how fragile the buggers are. You breath on them and they go out of shape. Especially critical is when the switch is being reassembled and the case closed, the slightest misalignment and it’s game over, they get bent or worse. :dunno:
Dear AK friends, thank you so much for your kind help. I think I messed up the switch during reassembling. I will never attempt to open these f*****g switches again. I’m not clumsy at all, I’m used to perform delicate procedures, but, these delicate contacts… Will throw them in the ultrasonic bath, like I did many times before.
From the logical point of view it is very unlikely that the same components in both channels go bad at the same time, isn‘t it? Next, the voltages were all OK,which would have been the only remaining possible cause. I was lucky and just found exactly this switch in eBay. Will report back as soon as I have performed the transplantation. Thanks again!
Just in case you weren't aware of this...The face plate cover needs to be bonded/grounded to the main board chassis when shooting these control amps. Either via screws or alligator clip jumpers. If ya don't, there will be confusion diagnosing it. Good luck sir.
:beerchug:
:beerchug:
Thanks, good to know. If it does not work with the new switch, I will shoot this amp.o_O :beerchug:
I replaced the phono input selector switch with one from an ugly donor C-60. Did not help, I still could read 100 Ohms ad the phono MM inputs and the sound was weak and dull as before. MC was fine, I could read 1k Ohm in the 1 kOhm setting. Inspected the pcb again at least10 times with a LED loupe, but couldn't detect anything abnormal.
Hallelujah! In the equalizer amp in front of the Dual FET's TR 121/122 there is only one component connecting signal to ground, C149/C150, which in my machine was a 100 pF capacitor. (Several years ago I had replaced the 220 pF cap with 100 pF film caps because I had an Audio Technica AT150 MLX, which needed a lower value to tame the treble a bit.) After I replaced these caps with the 220 pF original parts from the donor C-60 phono MM back to normal now. Isn't it weird? 2 defective film caps, their R was 100 Ohms.
I was so motivated from the success that I also could fix the defective input switch. I put it into the C-60. The next project, I think.
