I'm going to try to ask this question better:
I have a C220. CD player is hooked into the CD input, single ended. The tone controls are bypassed.
Which volume level on the C220 provides no amplification or de-amplification (unity gain) for the CD player input?
I think the only way to accurately determine that would be to measure the output voltage at the pre outs.
For example, if your CD player outputs 2 volts you would crank the gain up on your C220 until you measure 2 volts at the pre out.
Not enough volume? With a Mc275?
My Mc275 shakes the whole house...
What speakers are you using?
B.
I am curious as to why you are interested in this? Inquiring minds want to know...
Alberto
Setting a hi-pass filter or xo to 80Hz offers a number of advantages provided you have a quality amp or powered sub and xo. Most of an amp's power is used to produce low and mid bass frequencies, 20 - 80Hz. Using the amp to produce frequencies above 80Hz causes the amp to work less hard, avoiding potential distorion. The amp operates more relaxed and cooler and has more than enough power to handle the load above 80Hz. Based on the speakers being used, they also will benefit.
2 volts will overdrive and clip the MC275 as well as all most all other amplifiers.
Thanks,
Ron-C
You are running out of power on those speakers. You can double your power up to 200 watts and it will be a little louder. If you like loud music you will have to lose the low efficiency speakers with the low power rating.
That is just the way physics works.
thanks,
Ron-C
What specs should I be looking for in speakers if I like loud rock music with a MC275 (or two)?
Thanks!
Von Schweikert VR2s. 87db sensitivity, 200w max.
C220 -> MC275, I start hearing distortion between 50 and 60 playing an average loud rock CD (Oppo 980)
What size is your listening room ?
