dawgcatching
I have a C2300 on order that was purchased from a 2nd hand party. Very excited to get it into my system and try it out! I was looking for advice on interconnects, and whether to run balanced or not. I am pairing it with a set of Rogue M150 monoblocks, which have a balanced input, but according to Rogue, the amps sound the same via balanced or single-ended. My source is a digital Modwright Sony, also single ended. Should I run balanced through the C2300, or would it make a difference? Cables are currently Cardas Golden Reference. I would probably have to borrow a balanced IC for the amp-preamp connection.
I will let you know how it sounds.
