C2700 vs C22 mk 5 for vinyl-focused system
Alguymcgee
Hey all,
I got a line on a c2700 for a really good price. Im currently saving for a C22 mk 5, but i could grab the C2700 tomorrow. The C2700 seems like the better option for streaming, which is a plus, but vinyl is my priority so thats really just a tiebreaker. My question is: is there any discernible difference between the two for vinyl? Are there any considerations im missing? For what its worth, the c2700 is about 1/3 the price of a c22 mk 5.
Current setup:
Well Tempered Labs Reference TT with Grado Reference 3 MI cart
Mcintosh C29 preamp
Mcintosh Mc2155 powering highs
Mcintosh Mc2255 powerong lows
Fyne Audio F501sp speakers
Thanks!!
I have the C22MKIV. I use MC and am very happy with it. I think the phonostage in the C2700 might be a little more flexible and quieter. Since it also comes with an DAC, it’d probably be more of a Swiss Army Knife preamp solution. Either one will be a major step up from a C29.
I have the C22MKIV. I use MC and am very happy with it. I think the phonostage in the C2700 might be a little more flexible and quieter. Not sure why it would be better for streaming, though, as they’re both analog and would require an outboard DAC and streamer. Either one will be a major step up from a C29.
Good to know! I read that the c2700 has a good onboard DAC, hence the comment about streaming. But honestly I dont do a ton of streaming, just something to keep music playing when there's company ‍
Thank you for the input is very much appreciated it!
Actually (I was incorrect):
C2700​
2-Channel Vacuum Tube Preamplifier​
LEGACY PRODUCT
  • 16 inputs (9 analog + 7 digital)
  • (5) 12AX7A and (1) 12AT7 vacuum tubes
  • Supports up to DSD512 files
  • Comes with DA2 Digital Audio Module installed
From what I understand the analog sections of the C2700 and the current C22 are basically the same. The C2700 is essentially a C22 with additional inputs and outputs as well as the DA2.
I have a C2700 and I like it a lot but in a certain sense I kinda wish I had gotten the C22 instead since it’s totally analog with no firmware or screen so it should be relevant forever.
One of the main reasons I got the C2700 at the time was because I wanted the DAC but if the MDA200 was out when I got my C2700 I probably would have bought the C22 with the MDA200 instead.
