The C29 lives in the bedroom system with some tables, tuners, and an originnal MC275.
thanks,
Ron-C
Ron, not to get too far OT here, but how do you like that V-15 III?The top table is a SP10MKII with a 10" SME M2 arm and a V15 III MXR Shure cartridge...
thanks,
Ron-C
Caps, you use the ones that fit and are close to the voltage and size of the original. Bigger is not always better. Changing the Op amps to the latest low noise version is a good move.
If you want to do the low noise resistors, maybe it will be a gain. The Phono section already has these by the way.
All current McIntosh products use the low noise 1% or better resistors. We also Use Nichicon Rubycon caps.
Out of all of the gear from the 70s and 80s the Nichicon Rubycon caps seem to be the best at holding value. I don't want to dump on other cap brands from Asia but...
Thanks,
Ron-C
LN,
I will publish the C34V story with pictures in a week or two. No time now and I am on the road. Stay tuned.
Thanks,
Ron-C
Yes that is an old HP signal generator. The Packards live three houses behind me so I figure I should support them. An MPI-3, second table and second tuner are also in this system.
Maybe 1% LN resistors would sharpen the sound up a bit. They are in the phono stage already.
Thanks,
Ron-C
C34V update is coming very soon. Almost done...
Thanks,
Ron-C
