For anyone who has read through the "C2a vs C2x" post this is a continuation of it with an issue that was discussed in that thread. For anyone who hasn't it was discovered than my C2x runs at a much higher temp than the C2a. The temp seemed to be located on the left side which made the likely source the transformer. Anyways I decided to pull the C2x out of service to investigate and confirmed that the transformer is causing the extra heat. That in itself would be concerning but what is more troubling is that the transformer actually gets very hot when the unit it not switched on. These 2 pictures are taken roughly 25 minutes of the unit being plugged in but not switched on.
Back half of transformer
Front half of transformer
Ambient/chassis temp
At this point I switched the unit on and the checked 15 minuted later. The temp in the center of the transformer was getting into "concerning territory"
So I think it is fair to say that there is an issue with this unit and it will not be going back into service unitl it's sorted. After looking at the schematic it would appear as though there are 2 seperate transformers in one case. One is for phono and the other is for line, both of which are operated by the power switch although the line transformer is closed by the switch contacts and the phono is closed by relay contacts. I haven't tested anything but the problem would have to either be a failed/failing transformer, a failed/failing relay (has the typical relay "click" when turning on unit) or a failed/failing power switch for the transformer to be getting hot when not powered up. Even then im not sure why the transformer itself would be getting so hot under a low/no load condition.
Anyways if anyone might have some insight into this issue that would be much appreciated. There was a thread from many years ago with a similar issue but there was no resolution.
https://audiokarma.org/forums/index.php?threads/yammy-c2x-gets-hot.254899/
