C34V Monitor Amp DC offset
jlovda
Things I loved from the 60's and 70's
I measure 23mv offset on both channels. This comes to about 66mw for 8 ohms. Is this within the normal range? Awhile back one channel had a 2.5v offset and I burned out two speakers because I put both speakers on that channel trying to figure out where the distortion was coming from. They got repaired. I changed both differential input transistors with correct parts on the bad channel and corrected the problem.
Thanks
16mV - 50mV: An acceptable value, especially at the lower end of this range. 2nd harmonic distortion is probably twice to four times what manufacturer's spec calls for at higher frequencies. Probably not audible, as the distortion is mostly in the upper octaves. At the upper end of this range I begin to raise an eyebrow. :saywhat:
I'd say you're in the acceptable range of DC offset.
