Have you ever seen Yamaha use such labeling?I wonder if that a is truly the first one off the production line!
SwedenWhere are you located? Or maybe a better question is where was this amp located? It has a non-USA plug, if that matters in the discussion.
Where do you see this in the photos?Appears the GND wire from output board to chassis has been removed.
Tone Jump versus Tone defeat, who cares?
I agree. I found the Tone Jump was placed on the MKII unitsIt appears to be a different function. His CA-1000 has the tone defeat as all of them do on the left side by the tone controls AND a "tone jump" on the Audio Muting switch. The Audio Muting switch is a three position vs the two position on most CA's.
We both saw this unit on another Forum, it is a curious unit.It appears to be a different function. His CA-1000 has the tone defeat as all of them do on the left side by the tone controls AND a "tone jump" on the Audio Muting switch. The Audio Muting switch is a three position vs the two position on most CA's.
WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums
The double square symbol, or did I also get that wrong.Where do you see this in the photos?
Not sure what you think you got wrong. I was asking about the GND wireAppears the GND wire from output board to chassis has been removed.
What does the double square symbol mean? Specifically in regards to the GND wire.Not sure what you think you got wrong. I was asking about the GND wire
It means the unit is double insulated, and does not require a safety connection to electrical Earth (ground).What does the double square symbol mean?
