CA-3000 loses channel in one mode of low filter
The Fuxtor
Addicted Member
On the 40 hz low filter the left channel totally drops out? Unit was restored with the via thru holes all pinned as well. Switch was disassembled and cleaned and is not damaged internally? Don't understand why the switch works in the other mode tho?
I can't quite follow where the difference in signal travels thru this board tho? Anybody show me what path the 40hz travels ? It's gotta be something amiss on that travel.??
Thanks for this !!
I had disassembled the switch, cleaned it up and it's all good....
I'm guessing one of those via passes got missed and/or failed.?
Ok. Found it... One of the via connections wasn't connecting? Used a wire and directly connected and all back and good. Thx all
