CA-F1 on the bench
IIRC the originals should be 33Ω - 3 x 100Ω does it - maybe our intrepid restorer just didn't have any 33Ω. :dunno: - sloppy work though. :(
@Drayton mon , I should make clear that my comment was targeted more at the 'elegance' of how the restorer did the job than whether it made the unit functional. Were it mine, I would change the resistor 'mess', but I would be doing that work myself and that largely because it offends my sense of correctness.
Should you go to the expense of having those resistor groups and original caps swapped out? Purely a judgement call for you and hopefully others will weigh in with their advice.
That doesn't look fully restored. Some transistors and diodes look replaced but the electrolytic capacitors are originali
That doesn't look fully restored. Some transistors and diodes look replaced but the electrolytic capacitors are original.
The board, marked SANSUI F-2992 A, in the “restored” unit, appears to have spaces where there are Black Flag caps in the same board, in the JDM “unrestored” item. See photos
For some reason, there are also some extra white wires in the JDM unit, unless they are missing from the (multi-voltage) “restored” unit?IMG_2960.jpeg
Unfortunately I am currently having an extended rest from working on other people's units, with the strong possibility I will not start again.
I am happy to try and answer any queries you may have
Thank you, for taking time to respond.
As you are unlikely to take on work, on other
people’s units, might you be able to point me in the direction, of a competent person that might be able to help me out? (I live in North Shropshire)
Take care, mate
I appreciate your input….. I know next to nothing, about electronics, but that @mess” caught my attention, almost immediately
Thanks, I appreciate what you’re saying…. I definitely want at least one of them properly sorting out!
Now to search Yellow Pages
I am happy to try and answer any queries you may have.
As there are several differences between the two versions (most notably the Power Board), might I ask, where might one find a Service Manual, for the JDM version?
I got mine from 'HiFi Engine' but last time I saw anything about HFE, getting a login is difficult, so you won't be able to download the one they have. I need to check if AK has a copy in their database - I'll check this now.... - no, not there :( - not even the BA-F1 either !
If you DM me (I sent a 'starter DM' to you just now), with your email address I will send you the copies I have. (please don't send your email address in open forum).
It seems that the schematic is the same - with some minor component value differences, which are noted as "Japan Model only" etc, and of course the layout differences on the power board itself. I am not aware of 2 versions of the SM - this would be very unusual for Sansui.
Please can you start a new thread for your restoration(s)? - I will respond to further questions in that thread so we can keep them separate. - thank you. ;)
Please send starter link again…. I seem to have “lost” it….. I did try to have a private conversation, but it wouldn’t let me
I haven’t managed to work this site out, yet…..
