El Cavano
I'm running a length of cable from the output of my Audiobox recording interface to my Sony receiver (str-5055). It's a length of 15-20'. I used speaker wire, in a pinch.
Turns out there is distortion when I play the signal through my amp, though not when I listen directly on the recording interface via headphones.
I'm guessing that my cables are not adequate, and that I need shielding.
What sort of cable would work the best in this situation? Does the + connector go to the core wire and the - connector go to the ground/shield wire? I'll need a 1/4 inch connector on the box and RCA's on the reciever. Will my 1/4 connector need to be TRS?
Thanks for your help!
