Cable seperator products
soundhd
Have been reading about the advantages to keeping audio/video cables seperated from each other and off the floor to keep RFI and inducted noise out of the signal paths......does anyone know of any products or product manufactures that make and or sell these type of items?
If your wires are big enough you could pick up a set of auto spark plug separators. They are pretty cheap too :D
That's a very good idea.
Since all my wires are out of sight, I use pieces of cardboard, sometimes with tape to keep things in one spot.
Jack
Buy the split foam tubing used to insulate small copper water lines. Its cheap and very effective, also the split makes it easy to use. Home Depot, its where America shops for audio tweaks!
be a lot cheaper to just buy some high density foam, cut it into two inch strip, cut some slots into it and slide your cables into the slots. One it would keep them separated and two help to clean up your wiring. Just a thought.
I picked up some of that foam water pipe insulation at Home depot tonight. It is already has a slit in it for slipping on and off...will put it in this next week or so and let ya all know how it works out........
